本帖最后由 junsan 于 13-4-18 16:42 编辑 求助M977大梁数据,我是要做1:10的,大梁的长宽高分别要多少? 哪位兄弟有图的也希望支持一下!感谢 我用的是RC4WD的MOA车桥, 车桥数据:Zinc alloy housing Hardened steel gears Full ball bearings Powder coated in gun metal black Width: 193mm(Hex to Hex) Gear Ratio: 38.42:1 Designed to meet the 266mm comp rig width standard Weight: 1.18kg (front and rear) Engineered & Manufactured by RC4WD 。 |
