HN的新1/8 off-Road Truggy
查看: 5171|回复: 16| [复制链接]
pump_lx 论坛元老 发消息
发表于 06-8-16 07:59:11 |显示全部楼层 来自: 中国天津
MUTILATOR 1/8 OFF-ROAD TRUGGY
FEATURES:
● CNC machined steel large bevel gear.
● CNC machined steel pinion gear.
● CNC machined steel 62 tooth spur gear.
● 4mm thick aluminium front lower arm holder.
● 4mm thick aluminium rear lower arm holder.
● Ball type steering knuckle arm-L&R (Hard-coated).
● 4mm aluminium front and rear shock towers with multi mounting points.
● Long suspension geometry designed specifically to maximize performance.
● Aluminium servo saver connecting plate.
● Front 22 degree kick-up angle.
● New design threaded type big bore shocks with 3.5mm shaft (F/R).
● New 3mm thick glass fibre brake discs (F/R).
● Front spring steel universal Joint.
● Adjustable ackerman steering geometry design.
● Front and rear camber adjustments using strong steel turnbuckles.
● Front and Rear camber can be fine tuned to suit your track conditions.
● 2.3mm anti-roll bar in front and 2.5mm in rear,
● 3 pin racing flywheel and clutch shoes.
● Machined steel racing clutch bell.
● New design light-weight dish wheels with 17mm hex (B-28).
● Secure transponder mount system.
● New design B-29 fuzzy monster tires.(Traxxas Size)
● Drive gear ratio is optimised for .21 and .28 size race engines.
● 150CC fuel tank for longer run time.
● High flow 2 stage air filter for maximum engine protection and increased engine performance.
● M-36 Polished 3 chamber pipe with 9.5mm exhaust stinger.
SPECIFICATIONS:
Length: 535mm
Height:210mm
Width:  422mm
Wheelbase: 370mm
Total Weight:4300g
Gear Ratio:  15.77:1
G/Clearnance:70mm
Tyre Size: 135mm x 84mm
Engine: 21~28 Class
pump_lx 论坛元老 发消息
发表于 06-8-16 08:03:25 |显示全部楼层 来自: 中国天津
喜欢卡车~手头又不富裕的兄弟们的福音啊!
这个车是HN的Speed 9.5,Violator 和X1CRT.3款车的结合体!
调整简便,车架结实!有很好的行走表现!
配件的灵活性更高,可以选用升级配件也很多!
但价格会比X1CRT 便宜
pump_lx 论坛元老 发消息
发表于 06-8-16 08:10:29 |显示全部楼层 来自: 中国天津
继续图片,真想弄一台跑跑试试~
大冒險家 超级元老 发消息
发表于 06-8-16 09:06:34 |显示全部楼层 来自: 中国香港
WA............:em07:
f60 元老 Fans 发消息
发表于 06-8-16 13:20:07 |显示全部楼层 来自: 中国澳门
rtr多少米? 3000左右行嗎
gxrjj 论坛元老 发消息
发表于 06-8-16 13:52:58 |显示全部楼层 来自: 中国广东广州
好车啊`~想买~呵呵感觉轮子换一种就好了`
kiro 金牌 Fans 发消息
发表于 06-8-16 14:19:47 |显示全部楼层 来自: 中国广东广州
排气还有一个保护套
黑皮 元老 Fans 发消息
发表于 06-8-16 14:32:14 |显示全部楼层 来自: 中国湖北武汉
看起来!~!蛮帅的!~!~等等有米了,就弄一个!
发表于 06-8-16 15:13:12 |显示全部楼层 来自: 中国北京
ken00107 论坛元老 发消息
发表于 06-8-16 20:28:36 |显示全部楼层 来自: 中国广东深圳
是RTR版吗????期待出PRO版
