VATERRA Kalahari 类似卡车 Vaterra Kemora 拉力 mini 8ight 越野 上两款的底盘一样,就是车壳柱,轮胎不一样 而和mini 8ight的区别仅仅是去掉壳子换避震座加个尾翼就是越野了!!!(泛泛说) 有人会说底盘材质,无非就是一个尼龙的,一个金属的 车的宽度不一样,不知道是摆臂长度不一样还是底盘差速不一样。纠结!!! Type: Type: Type:4WD buggy 4WD Rallycross 4WD Desert Raider Scale:1/14 Scale: Scale: Length:11.49 in (292mm) 14-Jan 14-Jan Width:8.03 in (204mm) Length: Length: Height:4.33 in (110mm) 13.19 in (335mm) 13.18 in (335mm) Wheelbase:7.32 in (186mm) Width: Width: Weight:2.15 lb (0.98 kg) 7.09 in (180mm) 7.08 in (180mm) Chassis:2.5mm anodized aluminum Height: Height: Tire Type:Kingpin™ buggy 4.57 in (116mm) 4.57 in (116mm) Motor or Engine:4500Kv brushless motor Ground Clearance: Ground Clearance: Speed Control:Brushless 0.83 in (21mm) 0.91 in (23mm) Radio:2.4GHz DSM® technology Wheelbase: Wheelbase: Batteries:7.2V NiMH with EC2™ connector 8.27 in (210mm) 8.27 in (210mm) Charger:Included (not sold separately) Weight: Weight: Kit/RTR:RTR 2.12 lb (0.96Kg) 2.12 lbs (0.96Kg) Shock Type:Aluminum, threaded, oil-filled Chassis: Chassis: Ball Bearings:Complete Molded Molded Minimum Age Recommendation:14 years Suspension: Suspension: 4 Wheel Independent 4 wheel independent Drivetrain: Drivetrain: 4WD 4WD Tire Type: Tire Type: Rubber (IR compound) Desert/Dirt Tread Motor or Engine: Motor or Engine: 380 Non-Sensored Brushless 380 Non-Sensored Brushless Radio: Speed Control: Spektrum DX2L Included Batteries: Radio: 7.2V 1200Mah 6 cell NiMh Spektrum DX2L Charger: Servos: NiMH AC Peak Charger 110V-240V 2A Included Gear Pitch: Batteries: .5 MOD 7.2V 1200Mah 6 cell NiMh Wheel Size: Charger: 52mm NiMH AC Peak Charger 110V-240V 2A Kit/RTR: Gear Pitch: RTR .5 MOD Shock Type: Kit/RTR: Plastic, Oil filled, coil over RTR Body: Body: Polycarbonate/painted Polycarbonate/screened Ball Bearings: Ball Bearings: Full Complete Minimum Age Recommendation: Minimum Age Recommendation: 14 years 14 years |
