PART#:MRTC-SDL MR4TC -SDL LCG Touring Car Kit List Price : $520.00 Unassembled kit. The advanced features of Yokomo's new 'Super' touring car take shaft-drive performance to a new level! Newly designed carbon graphite main chassis, upper deck, front & rear shock towers, battery plate Drivetrain components have been lowered 4.5mm for lower center of gravity. New one-piece aluminum bulkhead and aluminum motor mount for easier maintenance. Upper deck has been positioned 7mm lower. Front & rear upper camber links are now designed to mount on the one-piece aluminum bulkhead (as opposed to the shock tower) to allow more precise adjustments to be made. Front ball stud king pins are also used. Pre-molded battery trays compatible with both GP3700 and Intellect batteries. Newly designed steering linkage. Machined aluminum linkage components are used for lower positioning, and precise movement. Aluminum servo mounts Heavy-duty suspension arms New rear dog bones Aluminum suspension mounts Titanium turnbuckles Full ball bearings. |
