国外网站上看的,够疯狂的,不知道还能不能控制的了。 I've been working on a Brushless Micro-T and today I drove it for the first time. I have everything but my LiPo packs so I had to try it on the 4 cell nimh pack. The Castle Creations PHX-10 controller can drive the truck slower then the stock speed control. It doesn't cog at all, it does have a very slight ramp up to full power though(I believe its the 4 volt LVC in the controller), keeps it from doing a wheelie - with the nimh pack anyway, based on the speed and torque it will be wheelie city with the LiPo pack. I am using the medium pinion gear, its obvious I can goto the largest pinion. The body fits with no rubbing, no sign of the motor warming up. The ESC is forward only and brakes when in the neutral setting so I disabled the brake, the slight drag of the gearbox and motor seems to be fine, I may add a slightly delayed light brake when I can fine tune it with the LiPo's. Once again peace has been restored in the RC world, all of my cars are brushless powered!!! Now where are my LiPo's !!! Equipment used: Micro-T with ball bearing upgrade Spektrum SR3500 receiver Castle Creations PHX-10 brushless ESC Feigao LPS 5250 brushless motor - 12x22mm 5250kv Deans micro connectors 4 cell Nimh pack at the moment, soon to be a 2 cell 250ma 20C LiPo I'll be doing a scale dragrace between a stock Micro-T and the brushless version once the LiPo's arrive. I have access to a full drag system including a 6 inch tree. I will also post the weight differences between stock and brushless/LiPo, as well as the runtime differences. |
