> Serpent F180 Kit 2wd (#300000)> Description · Image gallery (7) Brand: Serpent Product Type: Gas Cars > 1/8Kit version of the Serpent F180 1/8th scale formula car. Build it yourself kit, including all parts, bodyshell, pipe-set, tyres and clear building instructions. > Description Specifications- 1/8 scale rear wheel drive - Realistic Formula F180 body-shell (pre-cut) - Adjustable rear nylon wing - 5mm CNC machined chassis-plate - Lay-down, push-rod type suspension front & rear - Independent front and rear suspension - Adjustable front anti-roll bar - Pre-assembled RCC shock-absorbers - Angled engine mount for lower C of G - Compact polished tuned pipe system - Ventilated disk-brakes front & rear - Rear gear-differential (pre-assembled) - Centax clutch system - 2-speed automatic gearbox - Rubber profiled F180 tyres with hard foam inserts - Pre-mounted tyres on F180 spoked wheels Performance- Acceleration: 0-60 mph in 3 seconds - Top-speed: 65 mph Available in 2 versionsSerpent F180 kit #300000 (available start 2007) Build it yourself kit, including all parts, bodyshell, pipe-set, tyres and clear building instructions. Driver needs to add an engine (type .21, .26 or .28), radio-gear, fuel and starter system. |
