买了SAVAGE电子倒档,并按照下面的方法进行设置。 哪位能翻译一下? 谢谢! Neutral Point Setting:leave the throttle trigger in neutral position. Press and hold the setup button. The LED will glow brightly, then turn dim. Hold down the button until the LED flashes about once per second,then release the setup button. Reverse Point Setting:Push and hold throttle trigger to full brake position. Press and old the setup button. The LED will glow brightly,then turn dim. Hold down the button until the LED flashes about once per second,then release the setup button and the throttle trigger。 Neutral Point Re-setting:After reverse point setup,you must repeat the neutral point setup. Press and hold the setup button. The LED will glow brightly,then turn dim. Hold down the button until the LED flashes about once per second,then release the setup button. [ 本帖最后由 一塌糊涂 于 2007-3-10 11:54 AM 编辑 ] |
