Adapts to all .12-.26 RC engines on most chassis. Polished aluminum finish Top of the Super-Charger has the "RBINNOVATIONS.COM" decal High output turbo impeller boosts air intake by 50-200% and increases engine horsepower Low mass turbo impeller design minimizes power drawn from the engine Parts are precision machine from high strength aircraft grade aluminum construction. Auxiliary pressure port can be used to boost fuel flow to the the engine. This allows the engine to run consistently from a full to empty fuel cell. Fits the Savage .21-.32. |
