28级发动机,双速,直径7英寸车轮,RTR!还配有3通道10组记忆的FM遥控设备,参数看起来很正点哦。。。 Features: > Factory built with 3 channel / 10 model memory FM radio system. > Dual high torque, metal-geared steering servos. > Heavy duty 5mm bracing front and rear. > XTM's powerful .28 rear exhaust engine. > Polished aluminum rear exhaust tuned pipe system. > 8 threaded and polished aluminum oil-filled shocks. > Steel 2-speed with 75/70 size gearing for low end power. > Drive train uses rubber sealed bearings. > Large 11.4cm(4.5”) wheels with 17mm hex hubs. > Massive 17.8cm(7”) tires with foam inserts. > Steel alloy, socket head screws. > Huge 290cc fuel tank for long run times > Dust resistant receiver and battery boxes. > 4 steel vented brake discs. > Bevel geared differentials front and rear. > Front universal joints. > Large front and rear chrome bumpers. Specifications: > Length - 63.5cm(25”) > Height - 30.5cm(12”) > Width - 43.2cm(17”) > Weight - 6.35kg(14lbs.) > Wheelbase - 41.91cm(16.5”) > Tire diameter - 17.78cm(7”) > Ground clearance - 10.16cm(4”) with suspension extended |
