1/16CEN大脚
查看: 3630|回复: 13| [复制链接]
harley227 终极 Fans 发消息
发表于 07-4-29 22:12:20 |显示全部楼层 来自: 中国湖北武汉
Manual  Operating Instruction  Upgrades  Replacements  Action Shot  Exploded View
Project  "MG16-Unit"
Street Price around $200 - Available Feburary 2007
CEN Racing has listened to our customer requests for a smaller monster truck that could be driven in areas where the GST 7.7 couldn抰.  With the arrival of the MG16, also known as the MG16-UNIT by us here at CEN, you can have the same MONSTER nitro fun that the GST 7.7 and Nemesis dish out, but in a package about a quarter of the size.   Don抰 worry about where you can drive the MG16, just find a spot and bash!
Though the MG16 is completely Ready To Rock out of the box, you can rest comfortably knowing that if you decide to use your own radio gear the MG16 uses standard size RC components.  No more having to deal with the tiny mini servos with their weak gears that strip out from the tough beating that monster trucks dish out.  You won抰 have to find to shop around for the tiniest receiver to get your truck running.
The MG16 with its .stump pulling 2.5cc pull start engine gives the MG16 blistering acceleration. With the MG16抯 awesome power to weight ratio, you抣l still be able to smoke the larger 1/10th scale trucks in a drag race!  Don抰 be afraid that the power of the MG16 will just lead to you spinning your wheels, with the full time 4WD you won抰 find yourself short of grip to get the power to the ground.  Stop by your local hobby shop and check out CEN Racing抯 newest sidekick, the MG16!
Equipped with 75cc fuel tank and lightweight chassis, the MG16 provides over ten minutes of tire shredding fun on a tank of nitro.  Less refueling and more Driving!
The MG16 is full time shaft driven 4WD with a unique front bevel gear differential coupled with a traditional 3 gear transmission in the rear.    Notice the unique molded chassis, the center cutout allows for the drive shaft to at the same level as the chassis itself, this allows for the MG16 to have a lower overall CG for enhanced handling prowess.
Maintenance on the MG16 is a breeze.  With the simple chassis layout getting to the transmission and differentials are a piece of cake.  Fixed camber links and toe links cut down on the adjustments letting you focus on the more important side of RC, FUN!!
Notice the center drive shaft, its fully protected by the sides of the MG16 chassis.  With the MG16 you won抰 have to worry about readjusting belts, the shaft driven power With the full time shaft driven 4WD handling the horsepower that the 2.5cc recoil start engine dishes out is no problem!   And if you抮e skeptical that the 4WD drivetrain isn抰 enough, CEN SPORT has equipped the MG16 with a slipper clutch to provide enhanced traction and power transfer
Knowing that the MG16 will see action in the dirt and mud, CEN SPORT designed the MG16 with a fully sealed radio box.  Keeping your electronics safe and sound is critical to having Nitro RC fun day in day out
Aside from performance CEN SPORT抯 engineers designed the MG16 to be easy to service as well.  Remove 8 screws and the front differential is in your hands.  Just unscrew another 8 screws for the rear transmission and you have both front and rear differentials in your hands.
Using resilient composites instead of aluminum, the MG16 combines lightweight with rugged durability.  To reinforce the chassis, CEN SPORT designed the chassis with reinforcement gussets underneath the chassis.  A composite transmission brace ties the transmission to the chassis.   Without this brace the lateral and torsional forces caused by the engine would lead to stripped spur gears, broken engine mounts, and leading to a ruined day of nitro fun.  The MG16-UNIT抯 arms have been molded out of a composite that allows for increased crash durability but at the same time it is not so flexible that it does not let the suspension do its job.
Part of the fun of owning an RC car is being able to customize it.  The MG16 doesn抰 disappoint.  Hop-up potential??  Well the MG16 can use standard size 1/10th scale tires and wheels, so you won抰 find yourself short of new kicks for your MG16.  Along with alloy shocks, and a wheelie bar, there抯 plenty of upgrades that you can customize your MG16.
Completely Ready to Run  Skyion DSX Radio System Lighting fast Acceleration  Full time shaft driven 4WD
Ball bearing supported Reinforced composite chassis components Powerful 2.5 Engine  High flow manifold with rear exit exhaust
75cc fuel tank with filter Built in servo saver Big Bore Oil Filled Shocks  P & D Body
Sealed receiver and battery Compartment
Single Speed Transmission with Slipper Clutch  Adjustable Suspension geometry Adjustable toe-in and camber
High Impact front bumper  Stylish 2.2" offroad wheels High grip v-treaded off road tires
Compatible with 1/10 parts, Unlimited upgrade potential!!
发表于 07-4-29 22:15:20 |显示全部楼层 来自: 中国广东江门
发表于 07-5-1 21:51:42 |显示全部楼层 来自: 中国湖北武汉
还是调试问题
还是调试问题,油针和1/8的车不一样的,现在很爽了
QC2005 终极 Fans 发消息
发表于 07-5-2 00:40:09 |显示全部楼层 来自: 中国广东汕头
CEN是设计都很不错的车。1/16的这部在深圳的时候有玩过~~感觉容易翻车~~重心有点高,但调整一下还是OK的
