Spektrum DX3C遥控器
11-3-18 15:33| 发布者: admin| 查看: 8696| 评论: 10
Spektrum推出DX3C遥控器,这是Spektrum新一代的入门级遥控设备,三通道,20组模型记忆,全新设计的外观,LCD也进行了升级,带有SD卡,可对遥控器进行软件升级,只需安装4颗AA电池,配对接收机型号为SR300 DSM,DX3C的功能较为丰富,还带有一组可编程的通道输出。
Features
- Pre-set Steer Mix. For vehicles with 4-way steering, allows crab steering and 4-way steering.
- 20 Model memory
- 3 Channels: Steering, throttle, and an auxiliary channel allowing the transmitter to be used in almost any surface application
- 1 programmable mix allows any two channels to be mixed together. Allows for 4 way steering, dual brake servos, etc
- Adjustable steering wheel tension allows customisation of the tension to the drivers preference
- Choose the auxiliary channel setting right for the application; 2p, 3p, or linear Servo travel adjust
- Digital trim allows for precise trim adjustments
- Rolling selector for fast and intuitive programming of the transmitter.
- Steering rate adjustment
- Exponential allows customisation of the servo movement/speed to fit driving styles
- 3-5 character model names. Name models to a name that will be remembered, instead of just a number
- Up and down timers keep track of run time.
- Servo reversing allows the direction of servo travel to be changed to make installation easier
- Model copy for easy transfer of model settings between models
- Model reset to quickly erase model settings
- Sub trim to adjust the servo centre position to optimise installation
- Interchangeable rubber grips provide a comfortable fit for the hand.
- Multiple sizes are available.
Source: Horizon Hobby UK [horizonhobby.co.uk]
    引用 natkert 13-8-2 14:10
    为什么我觉得挺好看的
    引用 九千笑 13-5-11 10:09
    这遥控 有没失控保护功能呢?
    引用 cdx7758 11-3-22 21:34
    报价啊 屏幕小拉点  看样子被三合抢拉风头啦
    引用 250527437 11-3-21 10:14
    这牌子的控我都觉得巨丑
    引用 悠久之翼 11-3-19 23:16
    yangyi2329: 20组模型记忆,太牛了吧。
    这有什么好牛的?
    引用 nightkiss 11-3-19 12:46
    外表不重要,现在看价钱了。如果价钱高于3PL,那就没有市场了。
    引用 yangyi2329 11-3-19 01:45
    20组模型记忆,太牛了吧。
    引用 underguard 11-3-18 20:00
    不知道价格怎么样?可以升级软件倒是挺吸引人的
    引用 悲剧的开始 11-3-18 19:04
    的确很丑。。。 而且手感很差
    引用 悠久之翼 11-3-18 18:51
    巨丑,跟玩具一样
    查看全部评论(10)
