Team Orion Vortex R8.1 Pro 电子变速器
14-1-16 19:44| 发布者: rcfans| 查看: 8893| 评论: 1
Team Orion 推出全新 Vortex R8.1 Pro 1/8 竞赛级无刷电子变速器,专为BL有感马达设计。支持2S至4S锂电,支持690级马达。基于R10 Pro电子变速器特性研发而成,使用R10相同的软件,双感应线接口、金属外壳、内置6V/7.2V BEC、升级版散热风扇能够更有效冷却电变。Deans接头,可使用Team Orion的DSB-R编程卡进行参数设定。Vortex R8.1 Pro 将会在月底德国纽伦堡玩具展上亮相!
特性
– Specifically designed for 4S LiPo 1/8 scale racing
– Adjustable BEC voltage 6V or 7.2V for improved servo response
– Based on World and National championship winning technology – Dual Sensor Port
– Machined aluminium case
– Exclusive cooling fan protection and design for improved cooling – Ultra low resistance PCB and FET
– Highly customizable state of the art software
– Works with sensor and sensorless motors
– Forward/brake, forward/brake/reverse and forward/reverse (Crawler) function modes
– Status control by LED and audio tone
– Equipped with Deans high current connectors
– Optional DSB-R programming box available (ORI65153)
参数
– Rated current 180A constant 860A peak
– Type Sensor/Sensorless 2/4 pole motors 6 pole motors sensorless only
– Internal Resistance 0.00028mohm
– Function modes Forward/Brake, Forward/Brake/Reverse, Forward/Reverse (Crawler)
– Compatible motors Max 2700KV
– Battery 7.4V – 14.8V 2S-4S LiPo/LiFe
– BEC Adjustable 6V or 7.2V 5A max
– Size and weight 53.5x38x34 146g (w/fan)
    引用 晴忝尛豬 14-1-17 22:30
    续tekin的又一选择
