Team Associated SC10 RS RTR短卡
11-5-5 18:15| 发布者: admin| 查看: 44809| 评论: 3
Team Associated推出SC10 RS (Race-Spec)RTR短途卡车, 使用防水型XP SC700无刷电子变速器,防水接收盒,Reedy 3000KV无刷马达,V2蓝色金属油压避震器,V2限滑差速,Jconcepts轮胎,XP3-SS 2.4G三通道遥控器,XP S1903MG金属齿轮舵机,虽然是RTR产品,但是这辆SC10 RS是高性能的竞赛级产品!
Features
- 2010 ROAR National Champion short course truck
- XP3-SS 2.4GHz 3-channel radio system with XP S1903 metal gear steering servo
- New High-Power Water-Resistant XP SC700 Brushless Speed Control with Deans® Ultra Plug® battery connector
- Reedy 3300 KV Brushless Motor
- New Water-Resistant enclosed receiver box
- New Blue anodized aluminum V2 coil-over shocks
- Sealed gear diff with new heavy-duty gears
- KMC® replica hex-drive wheels front and rear
- JConcepts racing compound rear tires and inserts
- Championship short course racing truck body
- Composite battery hold-down strap fits NiMH & LiPo battery packs
- Realistic front and rear bumpers with AE logo rear mud flaps
- Molded composite low-CG chassis with increased strength
- 14 precision rubber sealed ball bearings
- Durable front and rear body mounts
- Rugged steel turnbuckles
- Fully adjustable suspension geometry
- Angled bellcrank “coplanar” steering with integral servo saver
- Vertical ball end roll-center adjustments front & rear
- Many Factory Team & Reedy option parts already available!
欢迎进入RCFans短途卡车讨论区参与讨论
http://www.rcfans.com/bbs/forum.php?mod=forumdisplay&fid=510
Source: Associated [rc10.com]
    引用 邦德座驾 11-5-5 21:40
    XP SC700,防水接收盒,Reedy 3000KV无刷马达,V2蓝色金属油压避震器,V2限滑差速,Jconcepts轮胎,配置很高的RTR啊。前轮改进成了结合器,方便换别的轮胎了。电池压板也改进了。好车!
    引用 speederhe 11-5-5 19:24
    混碳件 ...
    2驱无爱
    引用 dxjturbo 11-5-5 18:33
    沙发。。。。。。。
