LRP iX8无刷电子变速
11-9-16 13:13| 发布者: admin| 查看: 5299| 评论: 8
LRP推出高压无刷电子变速器给1/8类型遥控车使用。产品名为iX8,是理想的竞赛和跑街的高性能电变,支持2S至6S锂电,最高电压支持22.2V,有感、USB软件更新接口、有倒车模式。
2S-6S LiPo operation
Wide input voltage range (7.4V-22.2V) for versatile use, with a powerful 6A switching BEC
Sensored Design
Sensored technology for high precision and intelligent motor management
USB Software Updatability
Benefit from all the latest performance improvements and updates available at www.LRP.cc!
Special power profiles
Special power profiles for the finest adjustments in all conditions, including all team profiles.
Forward/Brake + Forward/Brake/Reverse
Fully adjustable drive-modes with different brake/reverse adjustments
Revolutionary Internal Temp Check System 3
Allows you to read out the maximum internal temperature of the speed control and motor
100% plug-able connections
No-solder design-maximum convenience. Includes ready-to-use wires for all connections
Cut-off voltage/LVC adjustable
    引用 dlzjn 11-10-12 23:48
    电容位置、接口位置容易进泥灰, ...
    引用 trx 11-9-17 18:47
    lrp的电流肯定低不了
    引用 hkn1516 11-9-17 07:58
    电容位置有意思啊,好盈不学学?
    引用 小文子 11-9-16 22:50
    帅气!就是不知道价格是不是比较昂贵!
    引用 晴忝尛豬 11-9-16 18:40
    支持多大的电流呢?
    引用 groovyice 11-9-16 16:06
    价格啥样?
    还有这电调怎么木有风扇捏
    引用 zhangdf118 11-9-16 15:00
    这个电变要什么价格啊?
    引用 WML 11-9-16 13:48
    SC的????????????????????
    查看全部评论(8)
