LRP S10 Blast SC – 1/10短途卡车
11-9-24 18:22| 发布者: admin| 查看: 10532| 评论: 6
LRP 推出S10 Blast短途卡车,来自S10车系家族。这辆S10短卡是四轮驱动,适合专业赛道或者日常娱乐。有RTR和非RTR版本,大容量避震、可调限滑器、RTR版本还装备了大扭力540马达和LRP数字电子变速器。
欢迎进入RCFans短途卡车讨论区参与讨论
Features:
  • Fully adjustable all terrain race suspension
  • Race-style airbrush body design, pre-decalised, Short Course Truck-All-Terrain body shell Special large-volume “Big Bore” shocks with 4-hole shock pistons for best shock absorbtion on every surface
  • Special large-volume “Big Bore” shocks with 4-hole shock pistons for best shock absorbtion on every surface
  • Fully adjustable racing slipper for controlled acceleration on any surface and best protection of the drivetrain Completely built with ball bearings
  • Low maintenance and efficient universal drivetrain
  • Battery holder prepared for the use with LiPo and NiMH batteries Left/right turnbuckles in front and rear
    Super strong front and side impact bumpers for maximum chassis protection
  • High-quality RTR package including special SC Truck high torque 540 size motor, digital LRP speed control, high precision LRP
The Non-RTR version doesn’t include these components.
  • Blue anodized aluminium suspension arm holder front and rear and motor mount
  • Race-proven VTEC Overdose SC high-grip tyres with foam inserts on black SC Truck style spoke wheels for maximum traction and speed
  • CVD driveshafts front
  • Robust 3-piece tub chassis for best protection of the electronic components, perfect weight distribution and easy maintenance
  • Steel spider differentials front and rear
  • Front and rear swaybars included
  • Robust rear bumper with cool and realistic looking rubber mud flapsA2-STX Sport II transmitter, charger, longlife LRP rechargeable battery, high-performance LRP steering servo
v
    引用 黑泡 11-9-27 13:54
    玩过此车,虽然不是高端产品 但是很耐用 玩起来很好玩
    引用 WML 11-9-26 13:38
    这个车子是RTR,有KIT的嘛?LRP的品质应该比这个要好啊,不然对不起LRP 3个字母了。
    引用 mikesue 11-9-25 20:45
    看齿轮箱的样子 好像 hs...p
    引用 2.5R飞了 11-9-24 20:20
    lrp 也有有刷马达啊..才知道
    引用 sandyhalo 11-9-24 19:36
    很没特色
    引用 zhukenda123 11-9-24 19:32
    看着这个车子- 感觉好简陋喔...
    查看全部评论(6)
