Losi 1/10 22T 2wd RTR卡车
12-1-15 14:08| 发布者: admin| 查看: 8947| 评论: 4
Product Specifications
Type: 2WD Stadium Truck
Scale: 1/10
Length: 15.75 inch (400mm)
Width: 12.99 inch (330mm)
Height: 5.63 inch (143mm)
Ground Clearance: 1.8 inch (45mm)
Wheelbase: 11.3 – 11.41 inch (286 – 290mm)
Weight: 66.6 oz (1890g)
Chassis: 2.5mm 7075 T-6 Aluminum
Suspension: Independent
Drivetrain: 2WD
Tire Type: BK Bar
Motor or Engine: Sensored Brushless
Speed Control: Sensored Brushless
Radio: Spektrum 2.4 DX3E
Batteries: Not Included
Charger: Not Included
Gear Pitch: 48P
Kit/RTR: RTR
Shock Type: Oil Filled Aluminum
Minimum Age Recommendation: 14 years
12
    引用 入了mo界 12-1-15 21:06
    没个车样   车宽标准??
    引用 tjchen2008 12-1-15 17:46
    要是 四驱的 多好。。。  ps:前脸太恐怖,。。
    引用 shi995800 12-1-15 16:43
    这个脸把我吓着了
    引用 zch 12-1-15 14:50
    配置真高啊
