Exotek F1 Ultra升级套件
12-3-3 18:55| 发布者: rcfans| 查看: 11091| 评论: 6
Race proven features include;
- Link type rear pod for exceptional rear grip. The rear suspension pod includes ball links and reinforced easy set side links.
- Optimized for use with 7.4v SHORTY for a more compact and lighter car.
- You have the option to mount the Shorty lipo Inline for more steering response or laterally for more rear grip and stability.
- Bottom plate only design helps generate more steering response. This coupled with the increased rear traction creates an overall better handling car.
- Easy 2 screw shock plate and battery removal. The battery can be lifted straight up and out without interference from the ESC or receiver.
- Includes black anodised rear zero rebound roll dampener and mounting bar.
- Includes Associated side pod springs and mounts. These are used to tune for steering response and pod level (tweak).
- US made premium 3.0mm quasi weave carbon fiber is used throughout.
- Unicrank steering assembly for smoother steering and lower center of gravity at the nose to reduce traction roll.
- Short style wheelbase- 260mm
- Compatible with any Tamiya F103.
- Compatible also with the 3Racing F109 if you install a F103 motor pod.
- Compatible with an F104W if you use F103 bodies.
Source:http://www.exotekracing.com/f1ultra-f103-f103lm-conversion/
 欢迎进入RCFans F1方程式遥控车讨论区参与讨论
12
    引用 yzxwcg 12-3-5 21:52
    哪能买到Tamiya  - RC F103
    引用 蜡包 12-3-4 20:41
    GT好啊,要是有DTM就更好了
    引用 姜韬8857 12-3-4 18:54
    销魂的东西啊
    引用 申占军 12-3-4 15:17
    很精致
    引用 super_弟 12-3-3 19:29
    8错8错!
    引用 弑魂 12-3-3 19:15
    我好喜欢。。。。~~~!!!
    查看全部评论(6)
