Kyosho TF6 SP电动房车
12-3-7 20:54| 发布者: rcfans| 查看: 10892| 评论: 8
Features:
- Narrowed front and rear chassis design for optimised traction
- New upper deck design to match flexibility along the entire chassis
- Overworked steering unit for optimal Ackermann steering that realises linear steering response feel
- New aluminium spool joint cup in front for improved durability
- Double joint front universal swing shaft for reduced power loss when steering
- Longer suspension arms for optimised roll centre and maximum grip
- Gear-type rear differential adjustable by different oil settings
欢迎进入RCFans电动平路类遥控车讨论区参与讨论
点击这里选购京商Kyosho商品
12
    引用 zwtnt168 12-5-31 18:10
    神马东西啊?电池还用胶带绑的。。。无语
    引用 garywong5368 12-3-8 22:38
    TMD貴得要死
    引用 红辣椒 12-3-8 14:54
    为什么要使用更长的悬挂摆臂 相比短摆臂有何优势吗?
    引用 shi995800 12-3-8 12:50
    4K往上飘~~
    引用 标哥哥 12-3-8 11:21
    要看看价钱有没有竞争力啊!!!!!!
    引用 zippo23 12-3-7 23:50
    底板有点417X的意思哦
    引用 凡阿特 12-3-7 22:05
    京商的CVD设计的不错
    引用 super_弟 12-3-7 22:02
    8错!
    查看全部评论(8)
