Serpent Cobra 2.0电越
13-3-6 01:35| 发布者: rcfans| 查看: 9100| 评论: 6
Serpent蛇仔正式推出全新811 Cobra 2.0版电动越野车。这是一台1/8四驱竞赛级电动越野车,在过去一年的新车研发过程中,811 2.0已经由车手驾驶出现在全球各大赛事,厂方在听取了众多车手的反馈意见后不断改良。2.0新版811电越转向反应有一定提升,尾部抓地力增强,传动系统使用更大尺寸轴承确保传动更坚固耐用,除此之外新车还有多处进行了升级或换用新零件,整体性能有了质的提高!本月中旬开始发货。
点击->这里进入Serpent品牌专区参与互动
Main new features
- new wider rear end with new geometry for more rear traction and an easier handling car with wider sweetspot
- rear shockabsorbers moved to the back of the shocktower
- longer rear shocks; with longer housing and shockrods for more travel
- rear wing with integrated holders for the ballraced rear anti-roll bar
- longer rear lower arms, new higher carbon shocktower, longer rear shock, new upright
- lexan mud-guards to mount on lower rear arms
- nylon mud-scrapers mount on the rear uprights
- improved differential gears - as already in the Be version
- larger bearings in steeringblocks and uprights 8X16X5 (2) and 15x21x4 (2),
- transmission using larger bearings 8x19x6 and 13x19x4 and new couplers for extra durability
12下一页
    引用 ddt999666 13-3-8 14:18
    支持搞团购
    引用 ferrarifan 13-3-6 09:54
    蛇的步伐很快啊…
    引用 sozh 13-3-6 09:49
    搞个团购吧
    引用 wjl7867302 13-3-6 09:43
    想知道价钱可以说一下吗?
    引用 只有一个愿望 13-3-6 09:24
    和811BE有啥区别?
    引用 艾默 13-3-6 07:47
    这个要多少米啊???
    查看全部评论(6)
