Mugen MBX7 Eco M-Spec 1/8越野车
13-8-18 17:54| 发布者: rcfans| 查看: 13523| 评论: 5
  • Heavy duty aluminum motor mount housing A (E2122A)
  • Heavy duty aluminum motor mount B (E2122B)
  • Small composite molder receiver and servo mount (E2313)
  • Multi-adjustable ackerman plate (E2312)
  • Stylish mid-cab X7 body (E1045)
  • 3mm A7075 hard anodized chassis
  • Lightweight conical diff gears
  • Straight cut conical and ring gears
  • Specially designed front upper and lower suspension arms, front hub carriers, rear suspension arms and hub carriers
  • 15mm hard anodized threaded shocks with 3.5mm shock shafts and rubber shock boots
  • 5mm A7075 aluminum front shock tower
  • 4mm A7075 aluminum rear shock tower
  • 5mm A7075 aluminum lower suspension mounts for optimized geometry
  • High down force white wing which is adjustable forward and back.
http://www.neobuggy.net/wp-content/uploads/2013/08/MG_6406....jpg
http://www.neobuggy.net/wp-content/uploads/2013/08/MG_6270....jpg
http://www.neobuggy.net/wp-content/uploads/2013/08/MG_6267....jpg
12
    引用 yushenggang 13-8-21 05:47
    也许追求精度遍找了大师给你装好了
    引用 随便玩玩ing 13-8-18 22:12
    这个嘛,老鸟就看看吧,这种属于土豪的菜鸟玩的!
    引用 13-8-18 21:11
    HAO
    引用 ferrarifan 13-8-18 19:52
    为何我对这种80%组装完成的东西顿时就没了兴趣?KIT在哪里?
    引用 wangfei555 13-8-18 19:32
    为什么不出kit的呢?这样少了一个很大的乐趣!!!
    查看全部评论(5)
