注册 登录
RCFans|遥控迷 返回首页
morrowwei的个人空间 https://bbs.rcfans.com/?93549 [收藏] [复制] [分享] [RSS]
日志
TRAXXAS E -RENVO
已有 1149 次阅读11-6-23 07:18
We Scaled Down Everything..Except the Power!
E-Revo Innovation, Precision,
and Performance—Now in 1/16 Scale!
  • 30+mph Out Of The Box…50+mph All-Out!
  • Velineon®Brushless Power with new VXL-3m speed control
  • Powerful Velineon 380 motor—largest in class
  • Ready-To-Race®With Included Traxxas Power Cell NiMH Battery
  • ALSO AVAILABLE WITH BRUSHED POWER!
A New Category Of Off-Road Excitement
Traxxas sets the standard for power, performance and innovation. Now, for the first time, all the speed, quality and capability you expect from Traxxas is available in 1/16 scale with the new 1/16 E-Revo VXL. At 14 inches long, E-Revo VXL is about half the size of the 1/10-scale E-Revo. But don't call it a "mini"—this is a whole new category of R/C performance and fun that no mere mini-model can match. Beneath the factory-finished polycarbonate shell, you'll find the winning suspension technology of the seven-time National Champion Traxxas Revo®, screaming Velineon®brushless-motor power, and the convention-busting innovation of the E-Revo.
Proven Traxxas Innovation
No detail was overlooked in our mission to bring all the capability, durability, and excitement of Traxxas' award-winning models to 1/16 scale for fast, affordable R/C fun. The E-Revo VXL is built on the race-winning, track-proven innovation of the Revo and E-Revo models. The standard-bearer of design excellence, the Revo's F1-inspired, rocker-actuated suspension has been expertly adapted to 1/16 scale with all its functionality and performance intact, right down to the oil-filled, threaded-body GTR shocks. This superior technology provides capability, performance, and tuning functions at the absolute pinnacle of truck design. The suspension and electronics are fully integrated into the semi-monocoque chassis design that stunned the world when it debuted with the E-Revo. Intricately molded as a single piece, the chassis balances strength and weight, function and aesthetics, convenience and performance to far surpass the standards of the "mini" category. In 1/16 scale, it is an even more impressive achievement of packaging and performance optimization that could only come from Traxxas, The Fastest Name In Radio Control®.
Class-Leading Speed
Some mini-models are "fast for a mini." That's not good enough for Traxxas. The 1/16 E-Revo VXL is just plainfast. At 30+mph with the included 6-cell NiMH battery, E-Revo VXL is nearly twice as fast as most mini models, and faster than most electric RTR trucks of any scale. Install a second 6-cell battery to unleash the Velineon Brushless Power System's full fury, and E-Revo VXL jumps to over 50mph—all with proven-safe NiMH packs. No other RTR truck, regardless of scale, makes it so easy and affordable to experience this level of high speed and wheelie-popping power.
The 1/16 E-Revo VXL now includes the Traxxas TQ 2.4GHz High Output radio system with Traxxas Link™. This new system offers the unbeatable convenience of "no channels, no crystals" 2.4Ghz technology, and the long-range security of a high-output signal—but that's just the beginning. The new, patent-pending Traxxas Link technology stores settings for up to 20 Traxxas Link-enabled models, with no naming or "model memory" settings required. Just power up the transmitter and the model you want to drive, and the settings for that model are dialed in immediately! The new TQ 2.4GHz High Output radio is also fully adjustable; steering and throttle end points can be set precisely, and the Multi-Function knob can be programmed to control Steering Sensitivity (Expo), Throttle Sensitivity (Expo), Steering Percentage (Dual Rate), Braking Percentage (Dual Rate), or Throttle Trim.
All-new and built specifically for Traxxas 1/16 scale models, the VXL-3m speed control and Velineon®380 motor represent the latest in brushless technology. Fully LiPo compatible with low-voltage detection for 2S and 3S packs and rated for 6-12 NiMH cells, this potent, powerful combo gives E-Revo VXL precise throttle control and blistering top speed. Patent-pending Training Mode™ lets new drivers hone their skills at 50% throttle. When drivers' ed is through, full power and 50+mph is unleashed with a touch of the EZ-Set®button. Big speed requires big horsepower, so E-Revo VXL and Slash 4WD VXL carry the largest motor in the "mini" category. The Velineon 380 is built to the same no-compromise specs as the Velineon 3500 found in Traxxas' 70+mph 1/10 scale VXL models. High-speed ball bearings. Sintered rotor. Neodymium magnets. Gold plated 3.5mm connectors. It all adds up to 50,000 rpm of pure power and track-searing speed!
Waterproof Electronics For No-Limits R/C Excitement
Now a hallmark of Traxxas vehicles, E-Revo VXL is the latest model to be equipped with fully waterproof electronics to keep the fun rolling in water, mud and snow while lesser cars stay on the bench. The patent-pending sealed receiver box houses Traxxas' new 2.4GHz Traxxas Link receiver and can accept aftermarket receivers as well, without compromising the 1/16 VXL models' waterproof properties. The new VXL-3m electronic speed control and high-torque, digital micro servo are sealed against the elements giving you the freedom to go places other cars wouldn't dare to venture.
100% Ready-To-Race®
The 1/16 E-Revo VXL is fully assembled with TQ radio system, Velineon brushless power system, painted and decaled body, pre-glued tires, and detailed instructions. A Traxxas Power Cell NiMH battery and charger are also included, making the E-Revo VXL truly Ready-To-Race. Designed specifically for the high-power needs of the Velineon brushless system, the potent Power Cell pack features heavy-duty construction, 16-gauge wires and Traxxas' exclusive High-Current Connector for efficient power transfer, run after run. Traxxas backs the E-Revo VXL and all of our products with top-notch support that is second to none. A staff of skilled representatives is on-hand to answer your questions via phone, website, or e-mail. Unmatched parts support allows the E-Revo to be serviced with parts and support from thousands of hobby dealers worldwide. Your investment is also protected by the Traxxas Lifetime Electronics Warranty. Traxxas goes the extra mile to ensure that your R/C experience is easy and fun (and fast!). Follow the details link above to go in depth on all the E-Revo VXL performance benefits and also be sure to check out the videos page to see it in action for yourself.
Also Available with Titan 380 Brushed
Motor and XL-2.5 Speed Control
All the precision and performance of the 1/16 E-Revo VXL (#7105), now with Titan®380 brushed-motor power! All the features of the 1/16 VXL E-Revo are built into the brushed version, including waterproof electronics, full ball bearings, brushless-ready transmission, oil-filled shocks—the works. The only difference is the power system, which features the new Titan 380 motor and XL-2.5 Electronic Speed Control. Designed and engineered by Traxxas, the XL-2.5 is packed with impressive specifications that are normally only found on more expensive high-end replacement units. The XL-2.5 features a completely waterproof design, three throttle profiles, Thermal Shutdown Protection, 6-8 cell NiMH compatibility and built-in BEC. High frequency operation combined with ultra-low resistance make the XL-2.5 an efficient and ultra-smooth fully proportional speed control. An exclusive feature on the XL-2.5 is the patent pending Training Mode™. This profile reduces the overall power output of the XL-2.5 by 50%, making it easier for young or new drivers to develop their control skills before unleashing full-power operation. 1/16 E-Revo's Titan 380 motor packs a high-torque punch with low-friction oilite bushings and a fan-cooled armature for lasting performance. Flexible, silicone-insulated 16-gauge wire keeps power flowing efficiently, and bullet connectors are used for convenient, no-soldering-required maintenance.
QUICK FEATURES ON 1/16 E-REVO VXL (#7107)
  • NEW TQ 2.4GHz Transmitter and Receiver with Traxxas Link™
  • Ready-To-Race®with included 6-cell NiMH Power Cell battery and charger
  • 30+mph with included NiMH battery,
  • 50+mph with additional NiMH battery
  • Revo suspension technology for superior handling and control
  • Full-time 4WD
  • Velineon®380 brushless motor—largest in class
  • Waterproof electronics
  • Torque-control™ slipper clutch
  • Sealed differentials
  • Realistic all-terrain tires with foam inserts
  • Traxxas High-Current Connector
  • Metric hex hardware
  • Rubber-sealed ball bearings
MODEL 7107: Fully assembled, Ready-To-Race®, with TQ™ 2.4GHz High Output radio system
with Traxxas Link™, Velineon®380 motor, VXL-3m electronic speed control,
7.2 volt NiMH battery & charger, and ProGraphix®painted body.
路过
雷人
握手
鲜花
鸡蛋
评论 (0 个评论)
