ego 超级元老 发消息
发表于 08-11-24 13:03:29 |显示全部楼层 来自: 中国广东广州
Tamiya TT-01D drift spec 特别版使用Nissan NISMO R34 GT-R Z-Tune车壳。
  • 4WD shaft driven bathtub chassis with coil spring damped, 4-wheel independent double wishbone suspension and sealed front and rear differential gearbox.
  • Drift-spec modifications include special suspension tuning, full ball bearings, sport-tuned motor, aluminum heat sink, CVA mini shock dampers and short springs and adjustable upper arms.
  • Polycarbonate body captures the GT-R’s beautiful shape including parts such as the front and rear fenders, wing, and the hood’s air outlet.
  • Super Driftech tires are made from resin and rubber compound specially designed for long-lasting drift action.
  • Includes Electronic Speed Controller (TEU-101 BK) and RS-540 Sport Tuned Motor.
  • Includes LED Light Unit (TLU-01) and 2 x white LED’s (Front) and 2 x red LED’s (Rear).
  • Add separately available LED lights for a greater sense of realism.
  • Add Tamiya LED Light Control Unit (TLU-02) Item 53937 for more control of light operations.
  • Wide variety of tune-up parts are separately available to further customize your machine.
  • 2-channel R/C system, 7.2V battery and charger separately required.
发表于 08-11-24 18:03:54 |显示全部楼层 来自: 中国广东东莞
可能有朋友又要说:这个早就有了
id1984 超级元老 发消息
发表于 08-11-24 18:06:54 |显示全部楼层 来自: 中国辽宁大连
经典!!
tonyshan007 论坛元老 发消息
发表于 08-11-24 22:04:23 |显示全部楼层 来自: 中国辽宁沈阳
这个是TT01D装R34壳  以前是TT01装R34  但是壳还是一样的R34
欣少 金牌 Fans 发消息
发表于 08-11-24 22:05:20 |显示全部楼层 来自: 中国广东广州
这早就有了~~
GT.5 金牌 Fans 发消息
发表于 08-11-24 22:36:06 |显示全部楼层 来自: 中国陕西西安
呵呵!....
YST的這個沙發坐的太舒服了!...
:lol
★厦门大马力★ 金牌 Fans 发消息
发表于 08-11-25 14:18:58 |显示全部楼层 来自: 中国福建厦门
还是喜欢R34。。
