Team Losi公布 JRX-S新车
查看: 6972|回复: 20| [复制链接]
发表于 04-10-19 23:42:00 |显示全部楼层 来自: 英国
[upload=jpg]picture/onroad/2004101923415170219.jpg[/upload]
Team Losi is proud to announce the release of their all-new world-class sedan racer called the JRX-S. This totally new design developed for the professional or serious racer who plans on racing in the big leagues. The cutting edge design incorporates hi-tech materials combined with years and thousands of laps of championship racing with some of the world’s best drivers and engineers. Although the name is a little retro the JRX-S is a totally new design from front to back with adjustability and features simply not found on other pro level chassis. The unique design is the only competitive chassis that is equally suited and includes adjustments critical for racing on both carpet and paved surfaces. Look for these exclusive features and hi-tech components;
• Inline center mounted battery & forward mounted motor
• Optimized short-arm suspension with integral sway bar mounts and up/down stops
• All chassis components pinned to prevent tweaking
• Diffs can be adjusted up/down and front/rear for CG and belt adjustment
• New construction two belt drive train that requires no idlers or tensioners
• Lightweight design and construction allows ballast placement options
• Completely adjustable roll centers, toe-in, anti-squat, castor, and camber
• Dual position shock towers for indoor/outdoor racing
• Center spool and one-way options
• Machined pure Carbon Fiber/Graphite chassis and upper braces
• All new single or double o-ring hard anodized racing shocks with Ti-Nitride shafts
• Pivot blocks with ball supported floating pivot pins
• New shock absorbing bumper and 5th body mount
• New Outdrive cups that don’t require saver rings
• Ti-Nitride suspension hinge pins
• Genuine MIP aluminum CVD’s
• Titanium Turnbuckle tie-rods and camber links
The design, adjustability, and assortment of specialty racer parts and accessories make the JRX-S the most advanced and versatile electric sedans avialable. The serious racer can quickly and easily change between indoor and outdoor set-ups in a matter of minutes. The JRX-S includes a neutral handling Skoda body and 24mm racing wheels ready for the tires of your choice. Look for the JRX-S to be available around the first of the year at hobby shops and racetracks worldwide.
LOSA0255 JRX-S Expert Racing Sedan Kit $349.99
