HD REAR UPPER PLATE (7075S/GUNMETAL)
Baja 5B/Baja 5T/Strong and durable.
This Heavy Duty Rear Upper Plate is a machined alloy option part for HPI Baja 1/5th scale vehicles.
This is an authentic HPI bolt-in upgrade part that is precision built to the exact factory specifications for a perfect fit. Heavy duty aluminum construction adds strength for resistance to crash damage and holds the rear of the chassis firmly in place. Machined from billet aluminum and gunmetal anodized for a custom look.
HD FRONT UPPER PLATE (7075S/GUNMETAL)
This Heavy Duty Front Upper Plate is a machined alloy option part for HPI Baja 1/5th scale vehicles.
This is an authentic HPI bolt-in upgrade part that is precision built to the exact factory specifications for a perfect fit. Heavy duty aluminum construction adds strength for resistance to crash damage and holds the front chassis firmly in place. Machined from billet aluminum and gunmetal anodized for a custom look.
This upgrade part replaces the stock plate #87484.
HD GEAR PLATE (7075S/GUNMETAL)
This Heavy Duty Gear Plate is a machined alloy option part for HPI Baja 1/5th scale vehicles.
This is an authentic HPI bolt-in upgrade part that is precision built to the exact factory specifications for a perfect fit. Heavy duty 7075S aluminum construction adds strength to keep the drive gears securely mounted. Machined from billet aluminum and gunmetal anodized for a custom look.
This upgrade part replaces the stock mount #87485.
ALUMINUM AIR FILTER MAINTENANCE CAP (ORANGE)
Baja 5B/Baja 5T/Covers air filter base when air filter foam is off.
This handy aluminum cap covers the intake of the carburetor to prevent dirt and dust from getting into your engine when cleaning the air filter. It’s machined from billet aluminum and anodized orange with a silver HPI Racing logo for custom looks. An o-ring seals out dirt, and a chrome ring makes removal from the engine easy.
Fits all HPI petrol engines.
Source : HPI |
