A Tenbol Motor Mount allows you to upgrade your 1/16 E REVO or 1/16 Slash 4WD to full size 540 Big Block Motor Performance! But Tenbol is not just about performance, it also helps you keep your cool. With proper gearing you can run longer without overheating, up to a half hour or more per charge. The Tenbol Motor Mount can be used to upgrade a VXL or XL-2.5 version to Big Block Power! http://www.tenbol.com/ 说是用这个就可以在车上装540马达~~~~~ |
