已经由日本玩家发表用这种方法实现反胎漂移,LZ还是很有才的。 I got information of new Counter Dori set up from Japan. The diff gear of F & R does not change it necessary. I just set a -1 degree camber on rear, -6 degrees camber on front, and loose front ball diff, then ran in a Yokomo single ring tire. The surface is asphalt. It's dosen't work in Arai (Polished Concrete surface). Please don't ask me anything, I don't know right setup yet. I just want to let you know. |
