发表于 09-11-17 17:50:49 |显示全部楼层 来自: 中国广东广州
Protoform have announced the immediate release of the all new R5-N 200mm gas sedan race body. Gas sedan bodies require numerous openings to be cut in the roof area to enable cooling and fuel filling and thus the bodies tend to become aerodynamically ‘dirty’ and inefficient. Protoform has designed a body to minimize the net drag losses caused by these openings. The unique side windows as well as the rear window contours enhance the efficiency of the linear airflow into and out of the body. Every feature, including the large rear wing, is within EFRA/ROAR/200mm Global Body Spec dimensions. The enlarged wing struts allow for the use of larger screws for quicker trackside adjustments and the center strut adds stability. Made to fit all the popular 200mm gas chassis this body is pulled in .030 lexan and is supplied with protective covering, decal sheet, window masks and wing hardware.
宁宁 超级元老 发消息
发表于 09-11-17 18:44:04 |显示全部楼层 来自: 中国北京
好看~~~~~~~~
chenlei996 长老 Fans 发消息
发表于 09-11-17 18:57:49 |显示全部楼层 来自: 中国辽宁锦州
车壳都挨地了,能跑吗?
张爽 终极 Fans 发消息
发表于 09-11-17 19:00:34 |显示全部楼层 来自: 中国北京
哈哈  车壳很漂亮
发表于 09-11-17 22:25:00 |显示全部楼层 来自: 中国广东广州
好明顯係另一款ADUI A5了.
kwok 发表于 09-11-17 18:57
这个便宜一点
sino 论坛元老 发消息
发表于 09-11-19 14:17:00 |显示全部楼层 来自: 中国广东广州
车壳都挨地了,能跑吗?
chenlei996 发表于 09-11-17 18:57
这位朋友你到赛场上去看看就知道了,车壳很接近跑道地面是很正常的
fei515 元老 Fans 发消息
发表于 09-11-19 15:24:01 |显示全部楼层 来自: 中国辽宁大连
不错 就是头看这边牛
hzf9911 超级元老 发消息
发表于 09-11-19 17:17:40 |显示全部楼层 来自: 中国广东深圳
