本帖最后由 466176004 于 11-5-7 14:58 编辑 直接将D1由轴车变成了皮带车。。。 Ever wonder if you could convert a shaft driven car to a belt driven one? D-Like has released a conversion kit for the Yokomo Drift Package, dubbed the Weight Shift-MEISTER! This is a direct conversion for the Drift Package Type A or B without any extra parts. This mid-shp motor conversion kit is hopped up with all the carbon fiber and aluminum goodies expected from a high-end drift chassis. Read the full article for more details about the conversion kit! The set includes: - Front Damper Stay - Rear Damper Stay - Upper Deck - Main Chassis - Front Bulkheads - Rear Bulkhead - Belt tensioner post, flange bearings, and flange pipe - Main Gear Adapter - Drivebelt rear - Drivebelt front - Diff Pulley 40T (x2) - Center Shaft - Center Pulley - Unicrank post, collars and parts - Servo Mounts, nut, Spring - 840 Ball Bearings (x4) - Turnbuckle · 38mm × 1 - Turnbuckle · 58mm × 1 - Screws, Shims, Ball Ends and necessary hardware 四月香港方面已经有货,估计不久就能从论坛几个名人那里订到了。。 价格查了半天没有结果,一个不明国籍的网站显示$299. |
