1st i want to say thnx for letting me join this kool lookin forum.everybodys builds look awesome this is an 1/12 scale oshkosh t3000 airport fire and rescue truck.i started this truck over 6 months ago. little by little i will bring you up to date i started with a 4x4 but later on i upgraded to 6x6 it will have a working roof mounted water cannon,lower doors will open and engine compartment will open,lights and sounds of the deal here i started with tirea and rims.the rims were mad from 3 different rims to get the width and style was looking for. the tires are from rc4wd the rails i have in stock and cut them to length, i beleive i cut them to 38 inches long the axles are f350 here the truck i want to do |
#1 box is paint and doors are on , still need to make the handles and roof will b one of the last items to make ive added the cab light lenses , wipers and the steps on this side styrene is in i mounted c-channel and made some corner straps to hold the tank in place 原帖地址?:http://www.crawlcanada.com/forum/showthread.php?t=15849&page=8 |
