Vanquish Products Ripper Project
17-7-29 16:45| 发布者: rcfans| 查看: 10744| 评论: 28
以制造攀爬遥控车车桥和升级改装零件闻名的Vanquish Products(以下简称VP)宣布将推出高端的定制攀爬遥控车升级改装套件 “Ripper Project”,让玩家打造一台极致的防滚笼式攀爬越野遥控车 。套件售价将高达1899美元,目前开始预订,定金为500美元,预计10月20日开始发货。这款限量制造的套件实际上是需要基于Axial SCX10-2车架进行升级,如此高的价格是有原因的,限量制造,并且采用超过45公斤的铝原材进行CNC加工,所以VP在预订说明内强调,定金是不退还的。
http://v.youku.com/v_show/id_XMjkzMTMxMTAwNA==.html
花费1899美元后,你将得到:
    CNC Milled Chassis - Driver Side
    CNC Milled Chassis - Passenger Side
    CNC Milled Chassis - Front Crossmember/Shock Mount
    CNC Milled Chassis - Roof
    CNC Milled Chassis - Rear Crossmember/Shock Mount/Spare Tire holder
    CNC Milled Driver Side Body Panel
    CNC Milled Passenger Side Body Panel
    CNC Milled Hood
    CNC Milled Grill with Rigid Q-series Light Mounts
    Laser Cut Rear Number Plate (2)
    Laser Cut Roof Panel
    Q-series Lights (Headlights)
    4" Rigid Light Bar (Red LED strip)
    Rocker Supports
    Delrin Rocker Skids
    Hood Vents (3d Printed)
    Front Radiator (3d Printed)
    40mm 12v brushless fan
    Battery Box (3d Printed)
    ESC Mount (3d Printed)
    Sway Bar Set
    Stainless Link Kit
    Hardware
完成整车你还需要:
    SCX10-2 Chassis rails
    SCX10-2 RTR skid plate (or original SCX10 skid plate)
    SCX10 Bumper that bolts in between the frame rails (not to the outside) and is under 3.75in wide
    SCX10 Rear chassis crossmember
    Axial 3-gear transmission (complete with slipper and spur gear assembly)
    Axial Bomber Interior
    Axial Yeti Fuel Cell
    Axial EXO radiator
    Vanquish Products SCX10-2 F9 front axle with servo on axle mount
    SCX10-2 knuckles and kingpin bushings
    SCX10-2 rear axle of either style (Currie RockJock or F9)
    SCX10-2 axle internals (gears, shafts, lockers, hexes, etc)
    SCX10 driveshafts (this truck has a wheelbase slightly longer than the standard 12.3in but most SCX10 compatible driveshafts should work without an issue)
    5 - Vanquish 1.9 wheels with 475 hubs (or 350 hubs if using the KMC XD Center Cap)
    5 - Tires and foams (max tire size of 4.75in, when using the maximum tire size you will experience some rubbing still)
    90mm scale style shocks (up to a 4in shock will work but larger bore shocks may have clearance issues with the rear sway bar)
    Bearings and hardware
http://www.vanquishproducts.com/pre-order-deposit-cnc-milled-ripper-project/
    引用 anhuan 17-7-31 22:42
    led大灯感觉不错
    引用 王冲 17-7-31 09:19
    全是慢镜头,如果正常速度播放,肯定跳的一逼,假到自己都像笑。。。。
    引用 nivea 17-7-30 22:34
    有人能说说为什么这么贵吗?
    引用 小锋卡卡 17-7-30 20:55
    45公斤铝做个3公斤的车,这1899刀花的值啊,我先回家把奥拓卖了
    引用 粤A等待 17-7-30 17:36
    这车太便宜了,买了怎么好意思拿出去耍?
    引用 yuzhuo1998 17-7-30 14:32
    AudiStig: 45公斤铝10来万 老铁想啥呢
    你怎么就不懂幽默呢
    引用 AudiStig 17-7-30 11:19
    yuzhuo1998: 卖便宜了,少了个0,45公斤铝啊,成本不得10来万啊,老铁们,我说的对不对
    45公斤铝10来万 老铁想啥呢
    引用 52866258 17-7-30 08:23
    一万多会买这个?加几千买小切得了。
    引用 Shaktani 17-7-29 23:57
    成本是不是就500美元。。。关键1万多买这个太Jb丑了。。。
    引用 壹柒年陆月叁日 17-7-29 22:47
    这车不便宜,老美要花半个月的工资了,而我要花半年…
    引用 caolemeng 17-7-29 21:41
    一入攀爬深似海啊
    引用 wonderfulin 17-7-29 21:32
    我感觉还行
    引用 天龙之舞 17-7-29 21:20
    一入微屁深似海啊
    引用 VOLKSWAGENLK 17-7-29 21:03
    咖喱鱼丸: 。。对于限量车只有四个字:爱卖不卖
    这个垃圾噱头,就是被如今整个论坛VP情节带动起来的……VP就开始趁热打铁了!
    引用 咖喱鱼丸 17-7-29 20:59
    。。对于限量车只有四个字:爱卖不卖
    引用 VOLKSWAGENLK 17-7-29 20:58
    真的,抢钱的理由真的多
    引用 unclemud 17-7-29 20:44
    哈哈哈哈 名字取得不错 死神呢 吓唬谁啊
    引用 danity 17-7-29 20:44
    还精度呢,爬车有必要去要求过多精度嘛,哪天mugen  seiki造个攀爬岂不是价格还要加个零?
    引用 速度热 17-7-29 20:23
    抢钱抢的理由如此之多
    引用 KevinXuan 17-7-29 18:43
    壕的究极玩具
    查看全部评论(28)
