The new REDS M7T. All-new design. Lightweight. Power and Performance. Reliable. M7T is personally tuned and assembled by Mario Rossi to ensure the best performance. Lightweight The new M7T is extremely light! With 310 grams of weight is one of the lightest engines in its class. The engine has been completely redesigned to save even further weight, maintaining high performance and reliability. New cooling system The new engine is designed for maximum performance in terms of cooling, with a new ultra-finned crankcase and new cooled combustion chamber. High performance ball bearings The engine comes with all Swiss Made ball bearings. The new steel-ceramic hybrid rear bearing ensure longer life and low friction at high temperatures. New composite carburetor The new composite technology provides extreme carburetion stability. Interchangeable venturi and single adjustment minimum needle, facilitating the engine carburetion to achieve high performance. Maximum power Thanks to the ABC cylinder configuration, 7 inlet ports and exhaust port with booster, the engine has high power at high rpm, incredible torque at low rpm and minimum fuel consumption. The cylinder makes the engine suitable for every type of track. Perfect balance Our latest generation crankshaft is balanced with two high density weights. Silicone filling reduces the inertia to rotation. Through the use of special steel and heat treatment, the component is particularly strong and surprisingly reliable. Flat piston All our 1 / 8 on road engines use flat pistons matched to a new combustion chamber to ensure high performance at high rpm. Made from a high strength aluminum bar, our piston is a true masterpiece of engineering. |
