Kyosho MP9e TKI 1/8 电越
13-4-11 03:25| 发布者: rcfans| 查看: 17922| 评论: 8
http://www.kyoshoamerica.com/assets/images/30897.jpg
Standard Features:
  • Ultra Low C.O.G - Ultra low center of gravity, lightweight and optimal weight balance all combine to deliver the ultimate racing weapon.
  • New Body Design - Newly developed body is slimmer and lower in height to realize aerodynamic characteristics for powerful down force and full inner cooling.
  • More Down Force - Bolted on large wing generates powerful down force. New ribbing at the back results in improved rigidity.
  • Composite Torque Rods - Roll center can be adjusted by changing the direction of the spacer inserted into the lower arm of the rear suspension. Also, the one-piece ball and washer ball-ends are an added maintenance feature.
  • Upright Servo - Servo is mounted upright for easy maintenance and is dropped 2mm to contribute to the lower center of gravity.
  • Extremely Light Weight - The smaller differential units on front and rear with grooved cup joints, aluminum balls and the flexing shape of resin parts effectively lightens the weight while giving the chassis rigidity, more durability and strength.
  • Wraparound Side Guards - Grooved face in side guard matches the thickness of velcro tape and prevents dirt getting inside the chassis. Complete wraparound side guards only found on Kyosho MP9.
  • Equipped With Mud Guards - Mud guards on the rear arm prevent dirt entering the drive shaft and getting inside the wheels.
  • We Have You Covered - 3 types of servo horns are included for various R/C systems (SANWA / KO / for JR, FUTABA and Hitech)
  • Hex Screws - Kit includes all hex screws enough said!
  • New Suspension Design - Newly developed suspension uses bushings for easy maintenance and rationalizes the setting order.
  • Optimal Race Settings - Fine tune for the optimal race setting with adjustments to wheelbase, track width, roll center, caster angle, toe angle and camber change.
  • EZ Motor Mount - The Inferno MP9e is equipped with Kyosho's own EZ gear mesh motor mount, all it takes is two simple screws and slide the whole motor till you get the perfect mesh.
  • Lightweight Universal Driveshafts - The new driveshafts feature a lightweight design and are made from durable steel. Installed at the front, center and rear of the drivetrain, all of the driveshafts feature a distinctive black finish.
  • Standard 17mm Hubs - Now you can use all standard 17 mmm wheels.
  • Full Ball Bearings - Full ball bearings throughout for maximum efficiency through the drive system.
  • Medium Rear Shock Tower - The MP9e is equipped with the latest components like the new Medium rear shock tower that helps out in difficult situations by giving you better handling in most conditions.
  • World Championship Quality - The suspension features double A-arms, which is the same type of suspension used on the world's most sophisticated performance machines. It's durable, so you have the confidence that it's going to hold up even under extreme conditions.
What is a KIT?
  • A KIT is a higher level vehicle that includes nearly everything you will need to build a rolling chassis. You will need to supply items like motor, esc, tires, wheels and radio equipment. Required items may vary from kit to kit so please see Required Items For Completion section for full list.
Kit Contents
  • Rolling Chassis (Kit)
  • Module 1 Steel Pinion Gear
  • Clear MP9e Body
  • Decals
  • Hex Wrenches (1.5, 2.0, 2.5, 3mm)
  • 17mm Wheel Wrench
12
    引用 jeisa 13-4-12 22:00
    前蝴蝶架感觉脆了点!
    引用 super_弟 13-4-12 12:56
    从理论上说 这是个好车  但从图片上来说。。。很低调呢。。。。。
    引用 longzaitianya 13-4-11 15:22
    经典好车
    引用 zwtnt168 13-4-11 12:39
    都一个屌样
    引用 CX199207175419 13-4-11 12:03
    这车应该可以价钱合适的话考虑入一部。
    引用 RC高手 13-4-11 09:23
    类似hpi的vozar,我还以为编辑写错了,TKI--->KIT
    引用 lhf1984 13-4-11 07:55
    坐沙发~~看图好象入门级 不想竞赛级
    查看全部评论(8)
