LRP S10 Twister 2WD越野车
11-11-9 19:57| 发布者: admin| 查看: 5531| 评论: 7
LRP推出S10 Twister后驱电动越野车,RTR产品,装备540级马达、LRP数字电子变速器、LRP A2-STX Sport III遥控器、充电器和LRP电池。相信这是一款性价比较高的电越产品,除了配置齐全,车架的设计也具备竞赛级产品的基因。
Features
Electric Offroad 2WD Buggy 1/10 scale
Completely built and ready-to-run offroad model – only RTR
High-quality RTR package including special high speed 540 size motor, digital LRP speed control, high precision LRP A2-STX Sport III transmitter, charger, longlife LRP rechargeable battery, high-performance LRP steering servo – only RTR
Adjustable all terrain race suspension
Drive train with ball bearings
4 piece oil-filled shocks with blue anodized racing shock springs for best shock absorption on every surface
Easy access battery compartment prepared for the use with LiPo and NiMH batteries
Sealed gear box for best protection of the transmission and a composite motor guard
Composite gear cover with best slipper accessibility
Race-proven VTEC Kamikaze and Groove high-grip tyres with foam inserts on black spoke wheels for maximum traction and speed
Fully adjustable torque controlling racing slipper for best acceleration on any surface
Heavy-duty telescoping driveshafts
Low maintenance and super efficient drivetrain
Composite tub chassis for best protection of the electronic components, perfect weight distribution and easy maintenance
Composite geared differential
Race-style airbrush body design, pre-decalised, aerodynamic-optimised 2WD
Buggy body shell with high-downforce tailwing for maximum stability
Blue anodized aluminium suspension arm holder
Easy to understand and detailed user manual including beginner and tuning guide
    引用 zhaoxin0007 11-11-10 05:53
    呵呵,车便宜啊~~~所以就别要求太多了,估计也就1000多一点点~~~~~~~~
    引用 bo68674 11-11-10 00:43
    具备竞赛级产品的基因?....hahahaha!
    引用 悠久之翼 11-11-10 00:13
    顶多算是入门级
    引用 pkqq123 11-11-9 23:33
    都神马年代了, 还用十字螺丝
    引用 zhousimeng 11-11-9 21:41
    晕,拉杆都是不可调的啊...
    引用 shi995800 11-11-9 21:13
    感觉前悬架好脆弱
    引用 大黄河流沙 11-11-9 20:10
    全是鸟语~~
    查看全部评论(7)
