Associated RC10R5.1厂队版
12-11-4 11:29| 发布者: rcfans| 查看: 11677| 评论: 4
http://cdn6.rccaraction.com/wp-content/gallery/team-associated-rc10r5-1-factory-team-kit/10r5-1_profile_md.jpg?8a12f1
Specifications:
Power Source: Electric
Terrain: On-Road
Body Style: Other
Scale Size: 1:10 Scale
Assembly Level: Kit*
Length: varies
Width: varies
Wheelbase: 259mm (10.2in)
Weight: varies
Drive: 2WD
http://cdn5.rccaraction.com/wp-content/gallery/team-associated-rc10r5-1-factory-team-kit/10r5-1_3q_r_md.jpg?8a12f1
http://cdn4.rccaraction.com/wp-content/gallery/team-associated-rc10r5-1-factory-team-kit/10r5-1_3q_clip_md.jpg?8a12f1
Features:
  • I.F.M.A.R. World Championship-winning Dynamic Strut front suspension features symmetric components with adjustable caster and track width
  • Updated motor mount and left rear bulkhead for increased durability
  • A 3-point upper pod plate with graphite motor mount cross-brace, optimized for brushless motors
  • Ultra-rigid 2.5mm thick carbon fiber chassis with integrated chassis stiffening rails featuring centralized LiPo battery mounting position that fits R.O.A.R.-approved 3.7V LiPo battery packs
  • Aluminum side spring retainers for easier and more accurate adjustments
  • Innovative through-shaft center shock
  • Side damper tubes reduce friction for smoother rear pod movement
  • Pivot-ball rear pod design with hard-anodized aluminum pivot balls and updated rear pod links
http://cdn4.rccaraction.com/wp-content/gallery/team-associated-rc10r5-1-factory-team-kit/10r5-1_3q_bodyoff_2_noelecs_md.jpg?8a12f1
http://cdn7.rccaraction.com/wp-content/gallery/team-associated-rc10r5-1-factory-team-kit/8022_rear-pod-links_md.jpg?8a12f1
http://cdn5.rccaraction.com/wp-content/gallery/team-associated-rc10r5-1-factory-team-kit/new-10r5-1_r3q_r_md.jpg?8a12f1
http://cdn7.rccaraction.com/wp-content/gallery/team-associated-rc10r5-1-factory-team-kit/side-spring-retainers2_md.jpg?8a12f1
12
    引用 喜玛拉阿星 12-11-5 18:07
    很有爱  但最大兴趣的还是后轮胎,有卖吗?
    引用 跆拳道小子 12-11-5 16:18
    看着都感觉快······爽爆了······
    引用 lpfno90060112 12-11-5 08:32
    挺帅~~~貌似前防撞没什么用
    引用 黑色飘移 12-11-4 12:56
    这避震...........
