Team Orion WTS锂电
12-1-30 21:23| 发布者: admin| 查看: 10822| 评论: 6
相关阅读:为什么遥控车要配重?
配重对于竞赛级电动遥控车尤为重要。首先,不同车型的比赛对车重有严格要求,车重达不到赛会要求会被取消成绩;第二,配重有利于车架的重心分布更合理,选择合适的配重重量和配重位置,让遥控车车架更平衡,配重是否合理将直接影响操控和车子的行走性能。
Newly designed carbon look case
Compact size and lightweight
Latest 90C LiPo technology
4000mAh capacity, ideal for off-road use
Off-center cells allow better weight positioning
3 weight slots for maximum adjustability
Weights made out of aluminum (22g) or brass (69g)
Adjustable weight from 204g (w/o weights) to 411g (w/ 3 brass weights).
Connectors located at the front and rear of the battery for easy connection
Switched battery polarities between front and rear to avoid misconnections
12
    引用 zwtnt168 14-1-16 22:48
    太傻比了,
    引用 kyc 12-1-31 10:33
    现在流行玩概念呀,ko的控是这样,orion的电池也是这样
    引用 shi995800 12-1-31 10:07
    看着就知道很贵
    引用 dengchaochao 12-1-30 22:44
    对于2WD电越,挺有意义。
    引用 xjypark 12-1-30 21:41
    90C?  哇 很贵吧。。。
    引用 凡阿特 12-1-30 21:26
    这个设计有意义吗?
    查看全部评论(6)
