Futaba 14SG 2.4GHz 遥控
12-11-2 09:57| 发布者: rcfans| 查看: 16056| 评论: 8
Futaba推出14SG 14通道 2.4GHz FASSTest航模遥控器。内置遥感功能、支持Futaba FASST和S-FHSS技术,128X64像素显示屏。支持多语言菜单,30组模型数据记忆,可外接SD卡扩充记忆和进行软件升级。菜单内置固定翼、 滑翔机和直升机特性设定。->点击这里进入Futaba品牌专区参与讨论
General features
- Channels: 12 proportional, 2 switched
- Compatible with FASSTest, FASST and S-FHSS protocols
- FASSTest telemetry – compatible with Futaba telemetry sensors (sold separately)
- Free user-updatable software
- 30-model memory
- 10-character user naming
- 10-character model naming
- Airplane, helicopter and glider programming
- Large, 1.75” x 3” backlit LCD screen with 128 x 64 resolution
- SensorTouch programming
- SD Card compatibility for external model memory and software updates (SD: 32MB-2GB; SDHC 4GB-32GB)
- Left and right assignable slider switches
- Two assignable rotary knobs
- Six assignable three-position switches
- One assignable momentary two-position switch
- One assignable two-position switch
- Comfortable rubber grips on the sides and back
- Wide top switch spacing
- Adjustable stick tension
- Dual ball bearing gimbals
- 4 vibration warning types
- Home/Exit; User Menu/Servo Monitor buttons
- Audio earphone jack (for telemetry alarms)
- 6V 1800mAh NiMH battery pack
- User stick calibration
- Trainer system
- Servo speed adjust
- 5 programmable mixes
- V-tail, Ailvator, winglet, motor mixing
- Trim mix
- Logic switch (condition switch only)
- Internal programmer for S.Bus servos
- User menu
- Servo monitor (neutral and moving tests)
- 2 count up/countdown timers
- Integral timer
- Model timer
- Quick model select
http://www.futaba-rc.com/systems/futk9410-14sg/futk9410-grips-lg.jpg
http://www.futaba-rc.com/systems/futk9410-14sg/futk9410-homescreen-lg.jpghttp://www.futaba-rc.com/systems/futk9410-14sg/futk9410-telemetryscreen-lg.jpg
http://www.futaba-rc.com/systems/futk9410-14sg/futk9410-quickselect-lg.jpg
    引用 Vengaboylichao 12-11-6 16:57
    居然还是单色液晶,肯跌啊
    引用 小雨HXL 12-11-5 12:21
    是啊,最多3-4千
    引用 千喜兽 12-11-3 20:19
    阳光小强: 肯定要好几W
    几千块钱的玩意儿,不可能上W
    引用 毛达 12-11-3 18:16
    明显T8FG 的小小升级
    引用 阳光小强 12-11-2 20:46
    肯定要好几W
    引用 蚂蚁会飞 12-11-2 18:58
    日货,让人又爱又恨
    引用 小雨HXL 12-11-2 15:30
    嘿嘿,价格是多少啊。
    引用 super_弟 12-11-2 13:57
    如果可以支持音乐播放,sd卡里面下点歌曲,边飞边听歌感觉很爽哦~~~~~~~~~~~~~~~~~~~~~~这难道就是音乐飞行?!
    查看全部评论(8)
