Tekin Pro4 HD无刷马达
13-3-14 14:11| 发布者: rcfans| 查看: 10124| 评论: 4
Tekin推出Pro4 HD无刷马达,这是一款加长型550级马达。扭力和性能都是竞赛级水平,适合2S-4S动力,非常适合1/10 4WD短卡使用。可以与原厂RX8电子变速器完美搭配。
Features:
  • 4 Pole 12 Slot Hi-torque 550 Motor Design
  • CNC Machined 6061 T6 Billet Aluminum Heatsink Can
  • Neodymium Sintered Magnets
  • Rebuildable Design
  • High Purity Copper Windings Maximizes Efficiency
  • Precision Engineered for Maximum Energy Conversion
  • Dual-Plug Sensor Wire Harness for use with all sensored systems
  • High RPM ABEC5 Oversized Bearings
http://cdn6.rccaraction.com/wp-content/gallery/tekin-pro4-hd-and-pro2-brushless-motors/tekin_pro4hd_4300_bck_640_31213.jpg?ff49d6
http://cdn5.rccaraction.com/wp-content/gallery/tekin-pro4-hd-and-pro2-brushless-motors/tekin_pro2tt2503_5800_bck_640x480.jpg?ff49d6
Specs:
Weight: 6.3oz / 179g
Shaft Dimensions: .60″x .125″ / 15.3mm x 3.18mm
Motor Diameter: 1.4″ / 35.8mm
Motor Length: 2.1″ / 52.9mm
Bearing Dimensions: Front: 5x14x5mm / Rear: 5x11x5
http://cdn6.rccaraction.com/wp-content/gallery/tekin-pro4-hd-and-pro2-brushless-motors/pro4hd_contentpageheader.png?ff49d6
    引用 海模小子 13-3-15 23:15
    图已看完,说点什么不呢?
    引用 gewanlu1 13-3-14 14:38
    和原来的PRO4有什么区别???
    引用 马环宇 13-3-14 14:33
    好东西,这得找老顾给带一个
    引用 tenshock 13-3-14 14:14
    哈哈终于出来了 !漂亮!漂亮
