现在在车子那个是华科尔的舵机有点慢0.16S 现在换了个SKYARTEC -03A舵机这个速度快点 Supply voltage: 4.8/6.0V Speed: 0.1sec/60 degree(no load running) Torque: 0.85kg.cm Operating current: 100mA Static current: 1mA Dead band drain: 10uses Connector wire length: 150mm Dimensions (L*W*H):21.4*11.5*20.1mm Weight:5.5g(less connector) |
