Transmission Tuning 变速箱调整 Adjusting the Slipper Clutch 调整甩块离合 Your Revo is equipped with an adjustable Torque-Control™ slipper clutch. The slipper clutch is integrated into the main spur gear on the transmission (see page 6). The slipper clutch is adjusted by loosening the spring-loaded locknut on the slipper shaft. Use the supplied 8mm open-end metric wrench. To tighten or loosen the slipper nut, insert the 2.0mm hex wrench into the hole in the end of the slipper shaft. This locks the shaft for adjustments. Turn the adjustment nut clockwise to tighten (less slippage) and counter-clockwise to loosen (more slippage). The slipper clutch has two functions: 你的Revo是装备了可调整扭力控制甩块离合。甩块离合和正大齿轮一起装备在传动上(参考Page 6)。甩块离合是通过松掉甩块轴上弹簧力支撑的紧锁螺母来调整,可使用配套提供的8mm扳手。要拧紧或拧松甩块螺丝,可用2.0mm的内六角扳手插到甩块轴末端的洞口内,就可用甩块轴调整了。顺时针转旋转螺帽上紧(甩离小),逆时针松掉些(甩离多)。甩块离合有2个作用: 1. Limiting the engine’s torque output to the wheels to prevent wheelspin on low traction surfaces and help to prevent damage to the gears in the transmission during on-throttle landings. 1.限制引擎扭力输出以免低牵引力表面轮子打滑,有助避免在加速落地中传输轴上齿轮被损坏。 |
